My 2003 Cayenne S' trip counter on the instrument cluster fails to reset
other than the trip counter, everything works fine.
I believe it is a contact problem ? is the button a detachable one that I can pull it out from the instrument cluster?
anyone has come across this problem? any relevant info is appreciated.
thks !
I had the same problem - just a case of poor contact. You may need to either change, or quite possibly, re-align, that plastic press-piece. Don't worry.
Thanks ! I fixed it earlier by "improving" the contact at the butt of the detachable button.
