I searched the forum and didn't quite find what I need. What is the trick to removing a 1999 996 C2 mufflers. I cannot get the inner bracket bolts out. One appears to be about 5 inches long with the angle curved towards the engine. Help!
Edited by valley996
Just take the muffler and bracket off together by removing the 3 - 13 mm nut on each bracket. The muffler then rotates down and out. In some cases it is easier to remove the rear wheels first.
I finally got them. I didn't see the 3 inside bolts. They were also rusted really bad. I'll have to use new bolts and nuts on reinstall. I sending them to Fister for an upgrade. Thanks for the help Loren.
