I couldn't find this by searching past postings. How do I remove the sunvisors to take off the airbag stickers? I see 2 torx screws on one end. What do I pry up, and how, for the other end? Where do I pry from, and what's the best tool to use? Is there any electrical connection I need to worry about?
There's a plastic lid on the other side, behind the hinge. Pull the visor up, you'll see the lid outline. Insert a small screwdriver to pop open the lid (it opens away from you, towards window). You'll find a single torx screw underneath it.
If you have the illuminated visors, there will be a wire attached in the rear.
Note, if you have a newer model, 03 and up, there is just a single torx screw at each end.
I removed the airbag stickers in place--- denatured alcohol in a cotton swap until it started to loosen then slooooowwwwllllyyyy pull up on one end while wiping under the sticker with the swab. I put rags on my seat for protection against drips.
