I replaced the clutch power spring on my 2002 Boxster S today and managed to break the switch mounted on the clutch pedal.
I'm going to order a replacement but out of interest could someone tell me what it does?
Its number one on the attached diagram.
post-58910-0-85799700-1293588468_thumb.j
Not sure which switch is which, but there are two functions that come to mind. There is a starter interlock switch that won't start the car until the clutch pedal is pushed almost to the floor. The second switch disconnects the cruise control when you barely push the clutch pedal. That should help you figure out which one you broke.
Does a couple of things; in US cars, you have to depress the clutch to start the car. The switch senses that and allows the car to start. The switch also releases cruise control when you depress the clutch.
