Had to replace my battery this weekend. It was on my list for preventative maintenance and then it stranded me on Thursday :rolleyes:
After test driving the car the boost doesn't seem the same in 3rd and 4th gear. That is.. the car doesn't seem to pull as hard as it did before in those gears.. Is the ECU re learning after disconnecting the battery? I have the GIAC flash and Techart exhaust.
Hope everyone had a great Christmas..
Unless power is maintained to the DME while changing out a battery, the DME will need to go through a relearning mode, which should not last too long.
