I have a weird issue with my driver's side door. When I use my key to unlock the door, it unlocks the door but when I try to open the door, it doesn't let me. I do see that the window actually goes down a little as is normal operation. When the driver's side door is stuck, I have to enter from the passenger side and actuate the inside door handle latch twice to get it to open. This problem seems to happen off and on. I'm wondering if something in the door mechanism just needs to be lubed. Anyone have any experience with this issue?
Yes, you need to open the door up and see if the latch is broken or dislodged or bowden cable is loose or broken or if something else is wrong.
Any of those can fail - so you need to open it up to see.
