I am almost done with my engine swap and I am running into a small problem. I have an 03 Boxster and am putting a 3.4 996 motor in it from an'01Everything seems to be running great. Idle is good, tons of power. The only problem is that the engine is throwing a 0349 phase sensor 2 camshaft hall effect 2 error code. I had new sensors put in but I am still getting the code in spite of everything running great. Could this just be an bug because I am using the 03 DME with the "01 motor? Any ideas for a fix ?Thanks,
