Hi
I've a Boxster track car with a 5 speed transmission. I'm thinking of upgrading it to a 6 speed from a Boxster S. Does anyone have any comments on any disadvantages.
Are there any appreciable weight dfferences / installation issues?
Cheers
Marcus
Five speed is lighter when you factor in all the other parts that are required for the six speed (rear hub carriers, etc.); have also noted that the five speeds often have the advantage in auto cross and DE events, possibly due to weight and ratios.
Keep the pre-2000 5 speed. Your acceleration is much better with that setup. Mine with the 2000 5 speed is frustrating in 3rd gear. Your final drive ratio is better for acceleration.
-Michael
When I was looking for my Boxster, I "thought" that I wanted a 6-speed because it would be like a having a 2nd-overdrive (as compared to the 5-speed) to lower the RPM's when cruising on the freeway (you know, do 80MPH and be only turning over around 2700 RPM or something like that).
But I was wrong in this regard. The 6-speed only lowers the RPM by about 100 RPM at 75MPH (120KPH) based on the speed vs. RPM graphs in the owners manual.
Edited by thstone
