Hi, good day,
I have a 05 Carrera S, when I turn on my PCM, initial on below the Porsche Logo, show a Red "Single CD Repair Kits", how to get if off ?
Thank you & appreciate any feedback ... :renntech:
Do you have a cd in the player?
Paul
I have the 6 CD Changer at the front bonnet & single disc at PCM, that means I can have 6 + 1 audio CD.
When push the power-on button, the PCM screen will start on with Porsche Logo, but mine below got the RED "Single-CD Repair Kits",
is the dealer re-install my PCM with the Repair Kits and not the full version ? My other functions are working ok, audio, sound, tel, info, trip, except nav (which I don't have the options).
:thankyou:
You can dis-connect the battery for five minutes. This
should reset everything.
Also, try ejecting the CD in the player. It could be
a bad CD disk.
Paul
You can dis-connect the battery for five minutes. This should reset everything.
Also, try ejecting the CD in the player. It could be a bad CD disk.
Paul
Dear Paul ... :thankyou:
I have try dis-connect the battery for 5 min or more, then re-connect the battery. When I switch-on the ignition, it show error msg "PSM Failure, PASM Failure",
after I drive it for a while, the error msh is gone. But the PCM still show the RED msg.
Maybe I should bring it back to dealer for them to check ... :oops: TQ & Appreciate your kind feedback !
post-11128-0-36469500-1293027627_thumb.j
Edited by gto3000
