Hi I'm very new here as now I have a small problem with a 08 Cayenne GTS
When I use my piwis tester to run through to find faults start from DFI module, Tiptronic module it all went through ok to the end.
but it could not detect Instrument cluster module it just says not found so I could not go in to reset service now.
Does anybody know what's wrong.
and there is a brake warning message on the onboard when you start the engine.
Is it because my brake pads are finish and I haven't change it.Is it that's why I could not go in to the instrument cluster module.
Thank you very much.
Edited by david4g63t
if you cannot see Tiptronic and cluster and if I assume correctly your piwis is a KTS520 knock-off then you have to have KTS firmware updated. you can also have a bad cable with K line disconnected
