Last week right after refueling I had a CEL. It was code P2190. It was removed by Porsche and yesterday again, ten minutes after refueling I had code P2188. Can someone help me on the possible causes of this CEL codes?
P2190 Lambda control adaptation FRAU (lower load range) - below limit value
Possible causes:
- Incorrect main filling signal from hot-film mass air flow meter
- Fuel pressure too high
- Injection valve faulty (dripping)
- Tank vent faulty (does not close completely)
P2188 Lambda control adaptation FRAU (lower load range) - below limit value
Possible fault causes:
Since it was after refueling I would suspect "Tank vent faulty (does not close completely)"
