About to replace my oil filler tube on the Boxster I just purchased. The aos was recently replaced which I'm guessing the vacuum of the faulty one put a hairline in the tube. Anyone that's replace one before and can recommend any timesavers would be greatly appreciated.
Garry
Garry
Garry:
The oil fill tube in a 986 Boxster is a three piece affair: the part that goes from the coolant tank flange to the middle tube, the middle tube, and the part that goes from the middle tube into the top of the engine. Make sure that you determine which piece(s) are cracked before you dive in there so that you don't have to wait to get an additional part that you had not foreseen.
There was a thread about 12 to 18 months ago here that covered the replacement with photos, etc... If I locate it before you do, I'll post a link to it.
Regards, Maurice.
