I was having issues with my stereo not working on a consistant basis when the engine was running. Yet sometimes when I turn on the lights and a/c it would start. After reading some of the forums on here it sounded like this was an ignition switch going bad. I replaced it with a new one and everything works fine other than the ignition won't start. I have checked the ignition fuse in the main panel and it is fine. Can anyone point me in the right direction before I blow a lot of $$$ at the dealership?
Edited by BoxsterLVR
Did you replace the black plastic switchpart? Or the entire assembly with a new white switch?
I replaced the entire electrical componant, It was white and then black where the harness attaches.
