looks like #1 will lower the engine and rotate about the trans bushing.Make sure the engine is supported if you have to take the nuts off. Watch for excess movement in the axles. Do not over stress the trans bushing either.
Other than that, an easy DIY.
Jim Greer
I replaced the waterpump and thermostat (160 F) on MY98 and chose not to lower engine. New pump on left old pump on the right. I removed passenger seat to access engine bay. Also replaced radiator fluid while I was at it.
Water pump changed in a little over 4 hours....a few breaks in there,,,didn't lower the engine. To All those that do this, remember to bleed the lines...drove down the road and warning light blinking....bleed the lines and all was fine
