Hi all,
I'm toying with the idea of an M97 engine swap right now, but wanted to know if anyone had some answers to these questions:
1) Are the mounting points on the M97 in the same place as the M96?
2) Presumably the exhaust ports on the engine are going to be flipped around compared to the 911 fitment so the manifolds cannot be used?
3) Will the M97 engine fit (without modification) to the transmission bell housing, or will that need an adapter?
4) Any other mechanical fitment pitfalls?
Thanks in advance for any help!
S.
HERE YOU GO , TRY THIS http://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/11-ENGINE-911_Engine_Swap.htm
Hi all,
S.
