Hi everyone
I have a 996 turbo and have recently just returned from a week or so away. When I got back I unlocked the door using my key, got in and then turned the ignition over. The car started but the alarm went off - so I turned it off and then did it again with the same result. When I tried for the third time the engine didn't fire up. Subsequently I have tried a few more times and the there is a clicking sound but no-sign of the engine turning over.
Any ideas gratefully received on the problem
Iain
:welcome:
And your battery is how old? If it is 4 years or older replace it. If it is newer then have it both load tested and have the specific gravity of each cell tested.
You are describing a bad battery perfectly.
