Hi Guys does anyone know if this will fit into a MY1997 ? I want to replace my turning lights to LED's..
Edited by Loren
fixed link
Does anyone know's this or which relay you can use or is used standard?
That flasher is the wrong style for your car, plus it "solves" a the problem by adding resistance ("load" in the posting) to the circuits; you can do this your self by simply adding appropriately sized (and much cheaper) resistors you can get a the local electronics hobby shop in the light wiring..............
