Hi Guys
First post so go easy please.
Cleaned the engine this afternoon. I used a hose on low pressure ensuring crucial parts where not made wet.
After about 10 mins the engine started misfiring. Do you think this will go away once the car has dried off?
Also whereabouts are the spark plugs and coil packs located?
Thanks for our help !
Coil packs are on top of the spark plugs. Get under the car and you
will see three red coil packs per side.
Hope your problem goes away.
Paul
Hi Paul
Thanks for the reply.
I've been under and can't see them. Are they near to the back boxes or in the middle toasted rear of car?
Hi Paul
The plug into the end of the spark plugs (under the heat shields) and are sometimes black in color.
Got them, thanks guys.
With washing the engine yesterday the misfire is still there.
Do you think I should take the coil packs/plugs out and dry them off ?
If you have access to a compressor, blow some compressed air on and around the coil packs to help dry any moisture that may have ended up there.
Otherwise, take the coil packs off and dry them manually. Make sure to inspect each one carefully for any hairline cracks. If there were any hairline cracks on any of them, moisture might cause grounding of that spark and result in a misfire.
Regards, Maurice.
You need to undo two torx sockets to remove one coil. It is
not a easy task. I would try the compress air and look for cracks
first.
You could also look for a DIY for removing spark plugs.
Paul
