I was plagued by a low-pitch buzzing from the dash area. Only happened at v. low speeds when engine was at low revs (e.g. approaching a stop), but not present at idle. Seemed to be less noticable with lower tire pressure. Followed all the good pointers from folks on the board, here - CD tray, doors, etc. I could swear the noise was coming from within the cabin, somewhere near middle of the dash area . But these rattles are like a darned water leak in your roof. Turned out to be the carrying handle from the battery vibrating against the underside of the battery cover. Removed the handle.
Happy Thanksgiving.
