What weight of oil should I use in my 84 911? is synthetic needed? I live in socal so its usually warm even though our winter just kicked in.
I searched but couldn't find a clear answer. Any help would be appreciated. Thanks.
I would recommend a 10W40 semi syntheic but not a full syntheic oil as your vehicle was never designed to run with those oils. We use Lurbo Moly here in the shop and have found it to work well.
Kurt
