98 Box with 101K miles. I don't know when it started, but I can here a clicking/ticking sound from the driver's side when the engine is running. Sounds a little like valve tapping, but I'm not sure. What should I check first?
Ray
Have you had the IMS bearing replaced at all 101K could mean thats on the way out if it goes it is catastrophic so take it to dealers or specialists to be checked
Ross
Edited by alstarz88
Ross
also could be a stuck hydraulic lifter
  • 4 months later...
Got the same issue couple of days ago. Any ideas?
check your spark plugs make sure their all tight, a few months ago I had a plug come out and it all started with a ticking on driver side the # 5 plug came out,had to have an insert installed to fix the threads
