Was referring to the springs/shock absorbers from the GT3 (w/PASM), and if the PASM will work when they are connected to the C2S.
A few guys have added lower GT-3 suspension links. They
have adjustments that you can make at the track.
Paul
What's the difference between the PSS10 you've given the link to, and B16 Damptronic that is designed to work with PASM? Or are they one and the same?
Most guys just get the stiffer pss10 shocks like below.
http://www.automotio...ml?dept_id=4994
A gt-3 is about 1" lower. It would be alot cheaper to buy a gt-3 then
to buy all the gt-3 suspension parts. You may even need to buy gt-3
half shafts for the suspension to work.
Paul
