I was recently driving in a spirited manner hard brakeing and cornering and my PSM off light came on. The PSM system did not engage to my knowledge or ABS. I tried the switch on the dash and it did not switch the system back on or did the indicator light work on the switch. I cycled the key off and on and everything works fine again, switch on dash worked again. I know the PSM system works because I have had it engage recently. Any thoughts...
Normal. You get some wheel slip and the light comes on.
It should clear itself with normal driving. BTW... the same thing happens after a California Smog Test - but clears itself after a few miles.
