Hi All,
Sorry if this question is in the wrong spot but I have 2 questions..
1. How do you get the front fog light/indicator/sidelight cover out/off to change the bulbs? - the manual shows some sort of plastic lever (that I dont have) and I dont want to scratch th surrounding area?.
2. The inner door handle on the drivers side - the illumination LED looks like it has slipped and whilst working, does not illumiate the handle. How does that part of the door panel come off?.
Also, I have Tooki on my PCM and it consantly comes up with 'phone not present' until you pull the fuse on the pcm (which also powers the tooki). I updated the firmware on this but it seems to have got worse?. Anyone else seeing this who has Tooki Bluetooth?.
Thanks all
Jon
Hi Jon,
you should have a CreditCard-like tool that came with your manual/warranty/papers if not you could use an old card, slide it on the inner side of the light and it will pop right out. very simple actually.
let me know
Tekky
