Looks like I need to replace the water pump for my 98 boxster, I looked at some of DIY for water pump installation, I didn't see anyone mentioning using any gasket maker/adhesive w/ the metal gasket.
is the adhesive/gasket maker not required?
Any input is greatly appreciated!
Cheers!
Cheers!
Only use the OEM type metal gasket, no sealant is needed, do not reuse the old metal gasket...................
