My 2004 Cayenne S is clunking on downshift from 5th to 4th. Dealership (South Centre Fine Cars in Calgary, AB) said I need a new valve body and listed a fault code of 1192 on my quote. What exactly is the 1192 fault code?
Also, they quoted $1612 for the valve body part alone...can get it online at porscheoemparts.com for $842+shipping. Does anyone know if I was to get the part and have a private mechanic install if I need to have any type of electronic resetting that can only be done by a dealership?
Thanks.
  On 11/10/2010 at 11:19 AM, Porschelibrarian said:
I have attached 2 pages from the Cayenne OBDII manuals which are included in the Cayenne service set I have. They cover the 1192 or P811 fault code you mentioned. See what your outside mechanic says. You and he will need the entire set.
Obviously I am showing the pages for educational purposes only.
/quote]
Thanks for the info...much appreciated.
