All the chatter about the IMS had me thinking... Does my Nov 2005 built C4S Cab have the revised IMS?
Running the VIN through "Scouser's decoder" :thankyou: shows a 2006 model year... It has the number 6 as the tenth diget in the VIN.
Can some guru out there put my mind at ease?
Edited by oskibear
Bear:
According to the LN Engineering website, "...Engines replaced or vehicles purchased in or after MY2006 should have the revised, larger single-row IMS bearing, identifiable by a larger 22mm nut in the center of the IMS hub flange..."
Since your dates are borderline, perhaps the next time you do the clutch you could inspect the size of that nut to put your mind at (relative) ease. A positive is that if it is the new bearing, it is beefier and has a better load rating than the earlier single row bearings. A negative is that it cannot be replaced without engine dissassembly.
Regards, Maurice.
