I'm changing my clutch on my 2003 C4S (with the RMS it seems, as a little oil is seeping out) and I've noticed the rubber coupling on the transmission end of the front cardan shaft is looking shabby and cracked. I can't seem to find a part number or source for this rubber coupling, does anyone have it?
Alex.
  • 5 months later...
Alex.
Try using BMW part number 26111225624-OEM-ID-E2E2217 / 26-11-1-225-624 / 26111225624 (depending on how you transcribe it). The part is slightly thicker, but is otherwise a good fit. I ran into this exact issue, and my mechanic ordered and installed this (after I told him that I had seen it as a "fix" on a number of boards) and it's been working great.
Had the same issue on my 02 C4 Cab. I replaced the entire shaft as the rubber coupling is not sold separately by Porsche (~$600 for the shaft). I am not familiar with the replair approach using the BMW part though.
Edited by tanny02996
