Hi just took the front bumper off my 99 996 to clean the radiators very easy definitely needed it when I took the right side marker light off it was doubled stick taped on the plastic on the car side is broken so the metal clip cant lock on does anybody know the part number of what I need, or a simple fix thank you
Jimmy:
The part number for the 996 front side marker light is 996.631.038.01 for the right (passenger) side.
If you still have the metal clip, you may be able to epoxy it back on with something like MarineTex, which makes a very strong bond.
Regards, Maurice.
  • 8 months later...
