hey guys,
I am looking at the porsche pdf part files for the water cooling hoses
there are quite a few and want to order the correct one,
1999 996 C2 NA 3.4 with Tip
passenager side, under the rocker , it a larger tube about 1 inch and is copper tube,
mine has been crushed almost flat and want to replace it
thank you !!!
Edited by dporsche74
I don't think what you are talking about is part of the cooling system. At least on my C4 all the coolant tubes ran in the center area. I am trying to remember but what you are talking about may be a fuel line of refrigerant line.
OK thanks
there is a large tube 1in running along a smaller `1/2 tube both seem to be made out of copper
it is not leaking anything either, no weird running issues either,
I wonder what it is
Item 6 - 996.573.091.01 Intake pipe -- US MSRP $146.78
Item 19 - 999.707.252.40 O-ring -- US MSRP $8.18 each
You will likely need to have to also replace the desiccator (item 3 - 944.573.143.01 Desiccator -- US MSRP $70.21) if the system has been open long enough to get moisture in. Also have the system checked for leaks and re-charged.
