My 11 is a daily driver, but even so, I do a lot of short in-town drives. When I'm away for more than a day I do use a battery tender (the junior version w/ its lighter accessory) and it works very well.
A good source for it and the cigarette adpater is http://www.batterystuff.com.
Edited by ADias
I know you had a question on proper storage before...take a look at the current TSB's. The fifth one down the list on page one shows the factory recommended storage procedures to follow...just temper those with common sense...
Jim
like Jim mentioned I would follow the tech bulletin. the airing of the tires does help on the flat spotting. also the Porsche battery tender works very well
Is Battery Tender the same as battery maintainer? If the battery is full charged, there is no current running to the battery, right?
