If you are replacing the calipers too then nothing changes from the rotor process. You will need to bleed the new calipers well though. See the brake replacement DIY and the brake bleeding DIY. Then let me know what questions you have.
One suggestion is that use a line wrench rather than a standard open end wrench to loosen the brake line nut where it connects to the caliper. I forget the size (I think 8 or 10mm) but a using an open end wrench risks damaging the nut, which will make the whole job much more painful. A line wrench (can be found at Sears or Snapon.com) wraps around 5 sides of the hex nut to prevent rounding it off.
Also, buy a selection of rubber tips at an auto parts place to use to plug the end of the brake line when you remove it. This will prevent brake fluid from spilling all over and make the bleeding process a little easier.
Karl
