My 04 Cayenne S is throwing 2 codes, no CEL.
DME:
907
Load management operat. on vehicle
electrical sys./DME control module
Present
No other codes or engine miss, slight tick from engine??
Coils?
Other one is the Air suspension, I get the "Faulty/workshop message" on startup now and than. Code is:
1772
Signal lead for pressure sensor
Pretty sure I can solve this with the VW Compressor rebuild kit.
Edited by Marc Gelefsky
Fault code 0907
Load management operation on vehicle electrical system/DME control module
Possible causes of fault:
- 'no display' Loads are/were switched off temporarily. The load management operation was enabled because of undervoltage.
Likely caused by a low battery - or battery replacement. I would clear it and see if it comes back (after checking your battery of course).
Fault code 1772
Pressure sensor signal wire
Possible cause of fault
- Short circuit to B+ in the wiring of pin 84 of the level control module
- Short circuit to ground in the wiring of pin 84 of the level control module
- Open circuit in the wiring of pin 84 of the level control module
- Level control module receives implausible signal from pressure sensor
- Pressure sensor faulty
- Level control module faulty
Likely a bad suspension air spring or connection.
If you have had battery problems I suggest clearing these codes and seeing if they come back. A low or bad battery can cause all kind of strange faults.
Thanks Loren! I cleared them and the 907 has not returned. Unfortunately the 1772 has returned and seems to give the Faulty/workshop error when the outside temps are cooler.
I dont suspect any bettery issues.
Sorry, you will likely need a PIWIS tester to further diagnose the level sensor/suspension issue.
