I'd like to disconnect the airbags for track days. Can I just disconnect the connector to the airbag control unit?
the airbag is not like the abs system where when power is restored and no faults seen the light goes out. You will need a Baum tools i-Scan or PST2 tester to turn off the light if you disconnect the airbag control unit
