V6 Drive Belt Replacement
Removing the drive belt 1. Remove front engine compartment cover. 2. Pull engine cover vertically upwards and off. 3. Remove connector tube from air cleaner to engine. To do this, loosen the tube clamp on the engine, unplug the electric connector on the mass air-flow meter and remove the two fastening pins on the air cleaner cover. 4. Remove the vacuum line on the throttle body from the connector tube. Then take the pressure pipe out of the engine compartment. 5. Mark the direction of
  • 6 years later...
40 minutes ago, Amnan-AHX4 said:
Hi  icant  remember if i ever change the drive belt, when is it due for replacement?
Exact model and year of your car, please?
