I just purchased this vehicle and noticed right head light wouldnt come on. First thougth was headlight is blown, so i replaced headlight but still wouldnt work, i checked fuse to see if it was blown but wasnt blown, i placed the good headlight into socket but still wouldnt come on... i need help!!!!!!
if the left headlight is coming on could the head light switch still be bad?
when i turned on my headlight switch it blew my right headlight fuse but not my left headlight fuse what do that mean?
Check the connectors on the back of the headlight and in the socket inside the fender.
If those are good then you likely have a bad headlight switch.
when i check the connectors, what signs am i looking for to see if connectors are bad?
Broken, corroded, pins pushed out.
Hello, the connector connected to fender is broken, the lens is not going all the way in for a good connect how do i replace the connector connected to the fender?please advise, thank you so much...
