This summer, I swapped a '99 996 3.4L into my '98 Boxster. I really love the conversion, but it definitely seems to be down on torque below about 4K RPM. Not having driven a 3.4 996, I don't know if this is normal or not.
The engine was programmed to RoW specs with the idea of using catless headers, catless mid-pipes, and an aftermarket exhaust, but because of fitment issues, it currently has catless headers, Boxster S cats, and an aftermarket exhaust. It has a Cayman airbox and filter. Does the computer need to be re-programmed for this setup? What else can be done?
What youmena by "catless headers"? You mention you have the cats fitted...
As far as I know you don´t need to reprogram the comuter (unless it was done wrong).
Any fault codes present?
Kare
Do you have Durametric Diagnostic software if so take a look at the cam timing. You can also check other possible causes with this software.
I have cats in the mid-pipes, not in the headers. No error codes, just doesn't seem like it has as much torque as it should.
