Using the Durametric tool on my 2003 I get a Fuel Tank Ventilation Fail under Engine Module, Ready Status. I do not have any fault codes. Any ideas would be appreciated.
Check your gas cap. I keep getting all sorts of Fault codes then looked at the gasket in the gas cap it was cracked. Replaced and no more fault codes. Cheap fix.
Thanks. I will check the cap and let you know what I find. Due to some work on the garage it be a couple of days before I can get to the car
I checked the cap and the "o" ring is cracked so a new cap in on the way. Thanks for the help! The "o" ring is $6.30 and the cap is $8.84.The Fuel Tank Ventilation error is gone.
Edited by dragonflyoh
