My 98 Tiptronic 996 C2 has a reverse problem recently when shifting from Drive mode into Reverse mode, the idle seems not stable and the rev has dropped down to 4000-2000 which could not hold on to the engine and leaded failure stop eventually. The problem seems obvious when the engine has warmed up or after a long distance travel. Due to this problem, i have been to the local garage and have the idling valve, sensor checked and cleaned but still cannot solve the problem. I would like to know has anyone here encoutered the similar problem and i will be much appreciated for your kindly advise and the possibility of the problem root cause.
