Loren,
I've been having an issue with the sunroof in that the open side of the switch won't work until you push the tilt/lift button first - I have tried retraining it and it will work for about 2 minutes then is back to it's old self.
When I took the access panel down where the roof open/close/tilt switch is I saw what looked like a motor and it looked pretty easy to install at home.
Does anyone have the directions handy?? Is it an easy job as it looks to be??
Thanks!!
T2
  • 3 years later...
