I want to clean out the car's air intake using BG44K (similar idea to Seafoam). Where is the best place to introduce the fluid into the engine? In other cars I've used the PCV vacuum hose, but with our cars that's kind of inconvenient to get to. Some people use the brake booster line, but that seems to only reach one bank of cylinders. Is there another place?
There are vacuum intakes on the boot on the left side of the throttle body. You could probably introduce the Seafoam there with some kink of an adapter.
I've never believed in this stuff. My thinking is that if your engine is running well you don't need any of these products.
You are probably no going to like it, but IMHO, the best place to introduce BG44K or Seafoam is into the nearest trash can. Both of these products have chemical make ups very similar to ladies nail polish remover; hardly something you would want to pour into a decent engine..................
THE CHEMICAL MAKE UP IN NAIL POLISH REMOVER YOU REFERRED TO IS: ACETONE. IT WILL EAT THROUGH PLASTICS, AND A BUNCH OF OTHER MATERIALS. DON'T INTRODUCE THIS STUFF INTO YOUR ENGINE. My 2 cents.
Edited by cakasa
BG44k is a fuel injector/fuel system cleaner. It is introduced into the fuel system (where you put gas)....it is not an air cleaner TMK. It is a good product and works quite well.
