Bought a 993 TT -96 and got only one key and no card with the code on it. How do I have a spare remote made if I don't have the code? Is there a way to trace it backwards from the VIN number or so?
Go to the stealership and they can look it up. They will want proof of ownership (title). They will also be very happy to sell you a second key and have the service center reprogram the key for lot of green backs.
On 993 rennlist forums there are lots of threads on how to reprogram a new key with code, and here http://p-car.com/diy/remote/ on P-car DIY. Tricky work, very complex detailed Rube Goldberg (got'a love German Engineering) procedure, but many have done it successfully. A few have given up and paid the stealership prices for the piece of mind. Good luck.
  • 11 years later...
I recently solved this same problem on my 1996 manual 911.  The dealership provided my 4 digit PIN or key code.  I bought a couple key blanks at https://mysecuritypro.com/keyblanks.aspx  for about $5 each. My blank was an Ilco .PO5 (capital "O" not a zero) and I had it cut by a local, automotive locksmith called The Door Heros for $10.  My local big box stores (Home Depot, etc.) could not cut this key.  I bought the USA 315 MHz key fob remote keyless entry for my 993 at https://www.ecudoctors.com/collections/porsche-993-1996-1998 for $150.  Their programming instructions and video did not work for me, but the instructions at this web site worked the first time:  https://993servicerepair.blogspot.com/2020/04/remote-entry-key-fob-programming-made.html  This approach is the simplest and least expensive of any I found found via many web searches.
