Boy did I go through the rears quickly on my 997 C4S. The middle bit of the tyre looks fine, even the outer edge still looks good... but the inner part went right into the cord when I wasn't paying attention. From the wear pattern, I would guess that they have quite a bit of camber to the set up... does this sound right or do I need a rear wheel alignment?
You can get harder tires if you want them to last a
little longer.
Yokohama and Michelin Pilot Cup tires are the softest.
Pirrelli have some hard tires.
Look at the hardness ratio on a site like tirerack.com.
The inner tire is the wear area for these tires.
Paul
