I've done some searching on this board (and others) and I'm trying to figure out what to look out for if my clutch is failing. I have an 03 996 TT with 29K miles. I wanted to know what the tell tales signs are of a clutch that needs replacing. I have had some creaking noise start coming out of my clutch pedal and it has a sort of weird feel when I depress the pedal (it just started recently.) However, when I drive, I can shift perfectly normal thru the gears. Can anyone shed some light on what to look for if a clutch is in fact going bad? my car is not a daily driver so I'm just exploring ideas...thanks!!
the easiest way to test your clutch for slip is to go to a higher gear, 4th or 5th and accelerate from low RPM. When the turbos come in, if the revs shoot up out of proportion to the speed increase, your clutch is either glazed severely or worn beyond specs.
  • 7 months later...
1. Drive about 40 mph on 6th gear
2. Press down the clutch pedal
3. Give throttle to raise rpm to 4.000 - 5.000
4. Release the clutch pedal (quickly).
The rpm should come down right away when you release the pedal. If the rpm stay up even for a second or comes down slowly, your clutch will soon bee done.
I bought my car from Porsche Dealer ten days ago. I didnt notice any clutch related problems when I test drove the car. However after a few rides after paying for the car I noticed some problems that I recognized as accumulator problems - thanks to rennlist. Yesterday when making a quick acceleration I noticed that when shifting to third gear the clutch is slipping. Then I performed the above mentioned four point test and got confirmation. Clutch is slipping.
I e-mailed the dealer yesterday. They promised to contact me today but they didnt. I hope I will not have to pay for the clutch.
Edited by Guybrush Wilkinson
More likely, your problem is a noisy clutch return spring (under the dash), not uncommon and can be fixed. Do a search on the subject..............
  • 9 months later...
Wondering what the typical cost to replace a clutch at an Indy is? Also, wondering of the Indy can set the "engage point" on the travel of the clutch? This one (though it's slipping) is set to release too high IMHO. I keep on killing the engine. I feel that a little lower would allow me better feel.
Any input on those two questions? Thanks in advance.
The "engage point" is not adjustable, a new pressure plate, disc and release bearing will solve your problem, bleed the system well also. A too high "engage point" indicates a worn clutch or/and a cracked pressure plate. Terms of costs in the US, i'm not informed, cant help with that, others will chime in.
  • 6 years later...
It looks likebI need to replace the clutch in my 2004 996TT.  I am getting some slip from 3k rpm to 4k rpm.  I am curious about going with Sachs OEM or other.
Any imput and recommendations would be appreciated.
