Hi all,
My newly purchased C2S had a Mobridge ipod/bluetooth module fitted, and the PCM phone hasn't been looped out. The result is the PCM phone is sometimes active, and other times, the Mobridge bluetooth phone works. I need to disconnect the PCM phone, located under the drivers seat (I have right-hand drive), but I can't work out how to remove the cables with the module in situ, and cannot work out how to remove it to disconnect the cables.
Does anyone know how to remove the cables so I can loop the MOST cable?
Meeko
you can disconnect the fibre optic cables (orange) and join them together with a coupler. That will stop the module coming on the most bus. the module is held in my 1 bolt at the front under the seat and lifting the seat up helps.
The module will also be programmed out of the system, with a PIWIS diagnostic tool, if you will avoid fault codes IMHO.
