The frame rail is tight, but the seat rocks back and forth a 1/2 inch or so. Depends mostly on position how severe. I assume its loosened up/wore with people jumping in and out over the years.
It's not just the backrest. Its the whole seat including back rest/seat bottom.
Is there any sort of tightening up maintenance one can do?
The seat bolts to the rails at the back of the seat - if you fully raise the seat and look from the back, you should be able to see these bolts. Other than that, I can't imagine why you would be getting as much movement....
It seems to be height dependant, its pretty firm still if its not low. If its as low as it goes it rocks pretty good. When I get a chance I'll fiddle some more.
Frame rail boltsare definitely tight, its something in the seat itself.
