Hello:
Looking for part number of engine temperature sensor for 1999 996. Also does the coolant have to be drained from the engine to change it???
TIA.....
Up to year 2000 the part number is 996.606.405.01, lists for $24.52, should be about $16.58 at Sunset, Suncoast or Porscheoemparts.com. But might be better to buy it locally as the shipping will rpbably cost as much as the savings. If you don't drain the coolant you will have some spillage, probably not that much. If you drain the coolant then you will need to bleed the system of air, kind of a pain without a system.
So it can be done without draining the engine?? I drained the engine when I changed the expansion tank, just had to bleed for a while, wasn't that bad. But if it can be done without draining the engine id rather go that way..
