Hi all. I just did my first full oil/filter change on my '95 993. I used the method that has you disconnect the oil return line and I dutifully purchased the three O-rings recommended to be replaced. Two of them have a good thickness and one is just a thread of a thing. The oil return tube has but one channel on it. Can someone advise where these three O-rings get positioned when replacing the oil return tube?
Thank you,
Keith
