The throttle pedal sticks when applying pressure. It's fine for regular driving, but at the track I lose the critical smoothness needed. The pedal sticks when applying gentle pressure and then gives way quickly as more pressure is applied. I'm looking for a smooth response to smooth pressure input from my foot.
Any ideas? Should I replace the acuator unit or is there an easier/cheaper way?
Thanks, John
Electronic throttle or not?
MY2000 on are all eGas throttles.
Chances are his accelerator pedal is worn badly and needs to be replaced, But you pretty much have to take it apart to see what is going on.
