The Porsche 996 twin turbo potential issues
The Porsche 996 twin turbo potential issues…. note: some of the links you need to be contributor to the forum to be able to view them…. Please take note there is nothing related to modification or upgrade..... After over 6 years experience with my TT and after searching four different forums ( renntech, rennlist, 6speed, renntrack) I came up with this list of possible failures…. Hope this help. Thanks to jjbravo, smdubovsky, Patrnflyr, Pumalex, FAST FWD, fdorn, Webtool1, rolfjahn, Ruiner, Da
Edited by jpflip
Nice list jp...I am not sure what common means (statistically speaking that is), but none the less a great resource list for many TT owners. Here are some others to consider for your list:
fuel filler problems (fuse or sensor)
amp - fuses
Key FOB issues (retraining, etc)
Battery draining
I didn't add any links, let me know if you want some. Thanks!
Edited by wross996TT
Thanks Wross for these suggestions, I will work on these later this week. I am thinking about the "common" word that I used and I am open to any suggestions. "possible issues", "weaknesses" (ouch), "possible failures", "recorded failures".... ???? I cannot believe that I forgot the fuse for the filler. I had that problem one night and could not remember which fuse!!! thanks for heads up!
Edited by jpflip
Just perusing the forums and see how helpful these posts are with possible "problems". Especially the fuel filler problem.
Thanks for all your research and work!
Welcome Kato. It was pay back time for me since I learn so much from Renntech and also save me trips to the dealer...smile.gif
I would be hopelessly lost if I hadn't run into you on these and other boards!!!!!!
Great post jp
Thanks Frank. Hope this is useful....
  • 8 months later...
Just bought a 2001 996TT so I am thankful for you posting this up. Fortunately I am only looking at the accumulator issue but hope to contribute positively to such a good resource.
Your welcome '2wheels4fun. There is also a section called "DIY Tutorials" that is also really useful, if you become a "contributor" welcomeani.gif
Nice one JP.
now all you have to do is get it into Alphabetical order and have it put into the DIY section as common faults/problems.
Then when ever some one wants to add to the list with a new defect/problem you could edit it and put the defect and potential repair in the list as well. In time we would have a comprehensive quick guide.
Frank. :thankyou:
Nice one JP.
Frank. :thankyou:
Good Idea Frank! Thanks for these suggestions. Of course I will need Loren's help with the "move" towards the DIY section. smile.gif J.P.
  • Like 1
